Venus OS v3.70~9 available for public testing
Also via regular browser I am greeted with a Login page.
apparently password 0000 worked for me. I’ve never had that before.
Any password will work :slight_smile:
The bug report is here already.
Hi all
Not sure if this is related to exactly this version, I just updated…
in previous versions I was able to change the VRM Instance of devices either via dbus-spy or the guy v2 under settings==>devices==>device name==> VRM Instance
I tried today, but it seems to be read only now.
This was very helpful for node red, if after a reboot device IDs changed…
KR
Since version v3.70~7 (also in v3.70~9), the battery display on the Brief page disappears approximately every 10 seconds (showing ‘battery not connected’). I am using SmartShunt as the battery monitor.
I rolled back to version 3.62 and everything is working fine.
Has anyone else noticed a similar issue?
After updating to 3.70~7 the custom input nodes of nodered don’t work anymore, so I don’t see PV generation and also no temperatures I inject via Node-RED.
Update: After removing the virtual device node, deploy and undoing the removal with crtl-z followed by a deploy it works again..
Yes same for me. I went back to v3.70~6
(I have a virtual battery and no error is shown. But there is a reinit every 10 seconds)
I noticed that my multiplus 2 gx 5000 doesn’t connect to the strongest accesspoint, but almost to the weakest.
There is an accesspoint one meter away from the multiplus which is not used by the multiplus.
This IS My, and you can See IT IS max.
the display works, but the akala does not
What’s the trick to get the Brief center battery info with 4 tanks 3.70~9?
I’m using the serial driver but I also tried the virtual temperatures, nothing.
Hello.
Since the second-to-last update, I’ve always had the frames. I think it’s supposed to simulate the touch panel. How can I disable that? It’s annoying.
Thank.
I usually try to keep my comments positive but in this I must admit I find the new framing rather annoying as well. For the lack of a better word it comes across as serving only to advertise the Victron brand which does not do the clean professional look much good.
Found an issues with one of the latest beta releases. Perhaps its already known and a fix is in the making.
The android tablet running the latest release of the GX Wi-Fi display. After one of the latest v3.70~X updates the screen shows a white bar in the top and the bottom of the screen.
I’m now running v3.70~9, but the bars are still present.
Keep up the good work! Really liking al the recent developments.
Greetings,
Sam
(post deleted by author)
