Venus OS 3.70 – Generator runtime frozen when /Engine/OperatingHours is static (Fischer Panda CAN)
After upgrading from Venus OS 3.54 to 3.70 on a Cerbo GX, I am observing a change in generator runtime behaviour.
System
  • Cerbo GX
  • Venus OS 3.70
  • Fischer Panda i8000 connected via CAN
  • Digital genset (NMEA2000 / CAN)
Behaviour in 3.54
Generator runtime increased correctly while the generator was running.
root@Cerbo-GX:~# dbus -y com.victronenergy.genset.socketcan_can0_vi0_uc303662 /Engine/OperatingHours GetValue
value = 2288880
Behaviour in 3.70
Generator runtime is frozen.
DBus investigation shows:
value = 32400
dbus -y com.victronenergy.genset.socketcan_can0_vi0_uc303662 /Engine/Speed GetValue
value = 2997.0
  • Engine speed updates correctly while running (~3000 rpm)
  • /Engine/OperatingHours remains static at 32400 seconds
  • Runtime in the UI does not increase
There is no internal accumulation visible in:
com.victronenergy.system
Observation
It appears that Venus OS 3.70 now relies exclusively on /Engine/OperatingHours for digital gensets and no longer accumulates runtime internally.
However, in this specific Fischer Panda implementation, /Engine/OperatingHours is static and does not increment in real time.
As a result, generator runtime becomes frozen.
Question
  • Is this intended behaviour?
  • Was internal runtime accumulation removed for digital gensets?
  • Should there be a fallback mechanism if /Engine/OperatingHours is static?
This behaviour change did not occur in 3.54. I tried rolling back and it works back as expected.
Thank you.
Thanks @Stefano, confirmed, will be solved.
