Off-Grid System Setup
- MultiPlus-II 48/5000
- Cerbo GX with Venus OS V3.79/V3.81
- AC-coupled PV inverter on AC-Out
- MPPT PV Chargers
- Gen connected to AC-In
- Gen is started/stopped by the MultiPlus Generator Relay Assistant
- System worked correctly on Venus OS 3.79 and below
Issue 1: AC Loads shown incorrectly in VRM
After upgrading to Venus OS 3.80 / 3.81, the VRM power flow appears to overstate the AC Loads whenever the gen is supplying power into AC-In.
Venus OS 3.79 (correct)
Multi:
- AC In = 2106 W
- AC Out = 2536 W
VRM:
- PV Inverter = 518 W
- AC Loads = 3045 W (correct)
Calculation:
2536 W (AC Out)
- 518 W (PV Inverter)
= 3054 W
which matches the displayed AC Loads of 3045 W.
Venus OS 3.80/3.81
Multi (correct):
- AC In = 1993 W
- AC Out = 2149 W
VRM (incorrect):
- PV Inverter = 702 W
- AC Loads = 4376 W (incorrect)
Expected calculation:
2149 W (AC Out)
- 702 W (PV Inverter)
≈ 2850 W
but VRM displays:
4376 W
which is significantly higher than the actual load.
The issue only occurs while the generator input is active and the MultiPlus is in “Assisting” mode.
The Multi’s internal measurements remain self-consistent (AC In, AC Out and DC current all balance correctly). The discrepancy only appears in the VRM/GX calculation of AC Loads after upgrading to Venus OS 3.80/3.81.
Issue 2: Generator tile shows “Stopped”
This has been present since at least Venus OS 3.79.
When the gen is actively supplying approximately 2 kW into AC-In:
- Generator tile shows ~2000 W power
- Generator state still displays “Stopped”
The relay of the MultiPlus controlling the gen is definitely active and AC-In is receiving power.
Question
Has anything changed in Venus OS 3.80+ regarding:
- AC Loads calculation in the VRM or Remote Console power flow,
- handling of AC-In sources,
- Generator Assistant state reporting,
- or the way “Critical Loads” are calculated while the MultiPlus is in Assist mode?
The 3.79 vs 3.81 screenshots seem to indicate a change in the load calculation, while the system configuration remained unchanged.
Thanks, guys!
