2 posts were split to a new topic: 3.62 connection issues
Suggested Message (English β Victron Forum Style):
Title: Venus OS 3.62 working perfectly with Smart Meter and MultiPlus II setup
Hi all,
Just wanted to share my experience regarding the new Venus OS 3.62 update.
I have a MultiPlus II system running in ESS mode, and a Victron Energy Meter (ET112) connected via USB to my Cerbo GX. After updating to version 3.62, everything has been working absolutely fine β no issues at all.
β’ The Smart Meter data is reporting correctly
β’ The system is not going into passthrough mode
β’ BMS, PV, and Grid readings are all stable and accurate
β’ No unexpected behavior or errors so far
Iβm actually finding the update to be smooth and stable in my case. Maybe the issue is specific to certain configurations β but for anyone using a similar setup to mine, version 3.62 appears to be working reliably.
Just thought it might help to balance the discussion with a positive outcome as well.
Cheers!
Good to here itβs all working fine the only difference with mine is a ET112 meter which reports correctly my batteries are pylon but that seems to be reporting correctly I also have gui mods which may be causing the issue not fully investigated yet , have node red running to enable relay 2 to control immersion heater on batt SOC and PV power so maybe node red issue
Was thinking about getting the victron meter which has quicker refresh rate and a new Cerbo as test and a backup
We shall see
I have lost one of my ET112 which is configured as my PV Inverter so I can monitor the AC panels I have. Currently only have one of the ET112βs showing. No GUI mods but was running the large firmware which I have now disabled. No modifications other than that. My Grid meter is working as expected.
