If a Shelly switch is unavailable, it disappears from the device list in GUIv2 shortly thereafter.
However in Node-RED, the status of the Custom Input remains “Connected” all the time.
Or is there another way to determine whether the Shelly switch is available or not?
Not sure what you mean. What type of Shelly device is this about and why does it become unavailable in the first place?
If I know that I might be able to give a more informative answer.
I noticed this effect on a Shelly 1 Mini Gen 3 running FW 1.7.5, but I suspect it also occurs with other Shelly switches.
A Shelly switches become unavailable (disappears from the device list) for example, when they are disconnected from the mains, or when they are outside the Wi-Fi range.
Thanks. I was able to reproduce it and fix it. Seems to be a bit broader than just Shelly devices.
The changes are currently under review, but expect it to land in v1.7.26 with a couple of days.
I’m sorry, but even with firmware version 3.80~49, the status of Shelly switches in Node-RED remains “Connected” after the Shellys have been disconnected from the power supply. They even continue to report the status they last had.
In the overview in the Cerbo GUI-V2, however, they disappear immediately.
I guess I was a little too quick there…
After I deleted the Shelly from the device list and then recreated it, the disconnection detection now works.
What doesn’t work anymore, though, is the automatic detection when the Shelly is available on the Wi-Fi again. The only solution here is to manually update the devices in the Cerbo GUI-V2.
I don’t know which is better.
