A very useful Node-RED tip from Andy at Off-grid Garage for assigning other functions to Shelly devices in Venus OS.
Including Downloads
Here is my solution for installing a Shelly PM1 Gen 3 as a virtual PV inverter. At midnight I store the Shelly’s energy counter, and so I can display the daily energy gain from the PV inverter in the Victron console:
"id": "9b8d5eacacb78531",
"type": "tab",
"label": "TomsBKW",
"disabled": false,
"info": "",
"env": []
"id": "c16a0bfd8dee5cea",
"type": "victron-virtual",
"z": "9b8d5eacacb78531",
"name": "TomsBKW",
"outputs": 1,
"device": "pvinverter",
"default_values": true,
"battery_capacity": 25,
"include_battery_temperature": false,
"grid_nrofphases": 1,
"include_motor_temp": false,
"include_controller_temp": false,
"include_coolant_temp": false,
"include_motor_rpm": true,
"include_motor_direction": true,
"position": "1",
"pvinverter_nrofphases": 1,
"fluid_type": 0,
"include_tank_battery": false,
"include_tank_temperature": false,
"tank_battery_voltage": 3.3,
"tank_capacity": 0.2,
"temperature_type": 2,
"include_humidity": false,
"include_pressure": false,
"include_temp_battery": false,
"temp_battery_voltage": 3.3,
"x": 120,
"y": 60,
"wires": [
"id": "35275ec1f27f2af7",
"type": "victron-output-custom",
"service": "com.victronenergy.pvinverter/101",
"path": "/Ac/L1/Power",
"serviceObj": {
"name": "TomsBKW (101)"
"pathObj": {
"name": "/Ac/L1/Power",
"type": "number",
"value": 11.3
"name": "",
"onlyChanges": false,
"outputs": 0,
"x": 790,
"y": 360,
"wires": []
"id": "6a8d240e49b53320",
"type": "inject",
"name": "permanent",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "2",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "0",
"payloadType": "num",
"x": 150,
"y": 240,
"wires": [
"042cf6a11932a8be"
"id": "ce2636d2240cf373",
"path": "/Ac/L1/Voltage",
"serviceObj": {
"pathObj": {
"name": "/Ac/L1/Voltage",
"type": "number",
"value": 0
"name": "",
"outputs": 0,
"x": 800,
"y": 240,
"wires": []
"id": "a7bfe9166a69cb9e",
"path": "/Ac/L1/Current",
"serviceObj": {
"pathObj": {
"name": "/Ac/L1/Current",
"type": "number",
"value": 0
"name": "",
"outputs": 0,
"x": 800,
"y": 300,
"wires": []
"id": "6a9257942e76f89f",
"path": "/Ac/Power",
"serviceObj": {
"pathObj": {
"name": "/Ac/Power",
"type": "number",
"value": 0
"name": "",
"outputs": 0,
"x": 780,
"y": 420,
"wires": []
"id": "e5b35642815ff4c2",
"path": "/Ac/Energy/Forward",
"serviceObj": {
"pathObj": {
"name": "/Ac/Energy/Forward",
"type": "number",
"value": 0.025317999999999303
"name": "",
"outputs": 0,
"conditionalMode": false,
"outputTrue": "",
"outputFalse": "",
"debounce": "",
"x": 810,
"y": 480,
"wires": []
"id": "b53fdec136fc0d9b",
"type": "inject",
"name": "atMidNight",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "01 00 * * *",
"once": true,
"onceDelay": 0.1,
"topic": "",
"payload": "0",
"x": 150,
"y": 160,
"wires": [
"712dd5e3c5be2f7a"
"id": "905529d86a6c8c30",
"type": "change",
"name": "EnergyMidNight",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "payload.switch0.aenergy.total",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 480,
"y": 160,
"wires": [
"9ab0ab5738569f61"
"id": "9ab0ab5738569f61",
"type": "change",
"name": "",
"rules": [
"t": "set",
"p": "dailystart",
"pt": "flow",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 670,
"y": 160,
"wires": [
"id": "042cf6a11932a8be",
"type": "shelly-gen2",
"hostname": "192.168.1.98",
"description": "TomsBKW",
"mode": "polling",
"verbose": false,
"server": "",
"outputmode": "event",
"uploadretryinterval": 5000,
"pollinginterval": 5000,
"pollstatus": false,
"getstatusoncommand": true,
"devicetype": "S3SW-001P16EU",
"devicetypemustmatchexactly": true,
"captureblutooth": false,
"outputs": 1,
"x": 310,
"y": 240,
"wires": [
"5132accc2b308517"
"id": "712dd5e3c5be2f7a",
"mode": "polling",
"verbose": false,
"server": "",
"outputs": 1,
"x": 310,
"y": 160,
"wires": [
"905529d86a6c8c30"
"id": "5132accc2b308517",
"type": "function",
"name": "Split BKW data",
"func": "let voltage = msg.payload.switch0.voltage;\nlet current = msg.payload.switch0.current;\nlet power = Math.abs(msg.payload.switch0.apower);\nlet energy = msg.payload.switch0.aenergy.total;\n\nlet startvalue = flow.get('dailystart') || 0;\nenergy = (energy - startvalue) / 1000.0;\n\nglobal.set ('pv_inverter', power);\n\nreturn [\n {payload: voltage},\n {payload: current},\n {payload: power},\n {payload: energy}\n];",
"outputs": 4,
"timeout": "",
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 320,
"y": 400,
"wires": [
"9553977e9932e6f1"
"a0d07accd66352e6"
"83bd7b882b32efca"
"677c58173e46c816"
"id": "677c58173e46c816",
"type": "rbe",
"name": "",
"func": "deadband",
"gap": "0.001",
"start": "",
"inout": "out",
"septopics": false,
"property": "payload",
"topi": "topic",
"x": 560,
"y": 480,
"wires": [
"e5b35642815ff4c2"
"id": "83bd7b882b32efca",
"type": "rbe",
"name": "",
"func": "deadband",
"gap": "1",
"start": "",
"inout": "out",
"septopics": false,
"topi": "topic",
"x": 560,
"y": 360,
"wires": [
"6a9257942e76f89f",
"35275ec1f27f2af7"
"id": "a0d07accd66352e6",
"type": "rbe",
"name": "",
"func": "deadband",
"gap": "0.1",
"start": "",
"inout": "out",
"septopics": false,
"topi": "topic",
"x": 560,
"y": 300,
"wires": [
"a7bfe9166a69cb9e"
"id": "9553977e9932e6f1",
"type": "rbe",
"name": "",
"func": "deadband",
"gap": "1",
"start": "",
"inout": "out",
"septopics": false,
"topi": "topic",
"x": 560,
"y": 240,
"wires": [
"ce2636d2240cf373"
"id": "7feee513b94636fb",
"type": "global-config",
"env": [],
"modules": {
"@victronenergy/node-red-contrib-victron": "1.6.64",
"node-red-contrib-shelly": "11.7.5"
Getting the data can easily be done by using four template nodes with the following code:
{{payload.apower}}
{{payload.voltage}}
{{payload.current}}
{{payload.aenergy.total}}
