I’m having trouble reading the text in the application because the font is very small. I don’t see any settings to adjust font size or scaling. Is there a solution for this? If not, could you consider modernizing the app (HiDPI support / scalable UI) to improve readability? Please.
Thanks, Jo. I’ve already tried the DPI/High-DPI compatibility settings, but they don’t solve it on my system Windows 11. The only workaround I’ve found is running it in 640×480 compatibility mode, but that forces the entire display (including other applications) into that resolution, so it’s not a practical solution.
I’m also surprised I haven’t seen others raise this topic here, which is why I’m bringing it up myself. My main point is that VEConfigure simply doesn’t feel like a modern application anymore: it lacks proper HiDPI support and scalable fonts. It would be great to see an updated, accessibility-friendly version.
It is a hassle to use the mk3 to usb all the time, because then i have to connect a laptop to it, and i want to use VRM to down and upload to the Multiplus. The question still is why is VE3 such an old fashion program?
Of course it matters.
2560x1600 at a 27" screen is 112ppi.
2560x1600 at a 34" screen is 89ppi. (lager pixels → larger VE.config)
2560x1600 at a 22" screen is 137ppi. (smaller pixels → smaller VE.config)
Thanks for the suggestions. For clarity: using VictronConnect via MK3-USB still means I must physically connect a laptop to the Multi every time I want to change something. In my installation the MultiPlus is not easily accessible, so that is not a practical workflow.
That is exactly why I use the VRM Remote VEConfigure download/edit/upload method. The problem is that the “remote” part is modern, but the required editor (VEConfigure 3) is a legacy, non-HiDPI application. DPI compatibility settings don’t fix it on my Windows 11 system, and the only readable workaround is 640×480 compatibility mode, which forces the entire desktop (including other apps) into that resolution.
So my request is not really “how do I zoom”, but a product request: please provide a modern, scalable (HiDPI) editor for RVSC/VE.Bus configuration, ideally integrated into VictronConnect or as a web-based editor in VRM, so remote configuration does not depend on an outdated UI.
