VE.direct questions
I’d like to connect an Arduino to a BlueSolar 100/20 and went through all the whitepapers, FAQs and github repositories I could find, but still got the following questions:
  • what are the “part numbers” of the plugs (with soldering pins) that fit into the VE.direct socket on the BlueSolar? (some term for searching on i.e. ebay)
  • when connecting the BlueSolar to a Cerbo, does the cable need to be 1:1 or TX/RX pins “crossed”?
  • is there a documentation on how to configure (protocol) the BlueSolar via VE.direct commands?
thanks in advance.
Jst ph 2.0 4 pin socket / plug.
Cross over type cable.
No idea on protocol to directly connect arduino, plenty info out there for rasberry pi.
