@mpvader 3.70~9 turns DESS off at some of my clients sites. And dess disappears from the menu under settings.
Going back to 3.62 solves the issue
Thanks! Is being looked into
@ All Beta-Testers:
Currently it looks like DESS is not properly starting after upgrading to 3.70~9. We could reproduce this once, doing a second reboot after the upgrade-reboot apparently makes DESS operational again.
So, if somebody is running into this and could confirm (or decline) whether a second reboot after the upgrade-reboot restores DESS-operation, could be helpful to eventually find the cause.
(Under Settings → System Setup → ESS → Dynamic ESS the Status will either state “Auto” or “Inactive”)
I can confirm a second or third reboot is how I think I got DESS (node-red, mode 4) partially operational again, but the DESS button in VRM was behaving erratic then.
After enabling DESS in VRM, the button became invisible (and DESS did not seem to work). Also the Settings → DESS menu was gone.
Changing the mode in node-red 0/1/4 also did not seem to do anything.
After a while (and maybe 2 reboots) it started working again but the DESS button still behaved weird and the Settings → DESS were still invisible.
Today everything is working as expected. (Button works, settings work and local node-red mode 4 flow works.)
Hi all, thanks again for your report.
Fixed per v3.70~19.
And we’ve seen once that this issue affected someone with v3.63 official.
So, there will be a v3.64 official version including this fix as well.
