V3.60beta and limiting PV inverter feed-in via SunSpec - please elaborate hoow to activate
OK, I just installed v3.60b~7 and my SMA inverter shows as compatible with limiting via ssunspec as it seems.
Now, based on the change-log - as a non-english speaker - I find the notes confusing, with regards to enabling the limiting.
So, when I enable the setting in the PV-Inverter settings in the GX, how do I actually limit grid feed-in up to a certain level?
My installed PV array has 20kWp … how can I limit feed-in to 70% =14kW of the said 20kWp installed?
Is it by simply setting AC-limit feed-in in ESS settings to 14kW?
And will it work, although my PV inverter is located on AC-In?
Missed this one totally, apologies for the late reply.
See here: Help needed - SMA, Solar Edge, Kostal, Enphase and others
