I have tried this release twice now and each time i have had to roll back to ~60 because one of my five charge controllers goes missing. I have a Venus GX running 2 charge controllers connected via VE Direct. One connected via USB (Victron USB cable) and the other 2 connected to USB using one of these Isolated 4 port USB to TTL UART FTDI - DuPPa One of the charge controllers connected to the USB to UART connecter doesn’t show up in the UI. It also displays the Float LED and Error Code: #67 - No BMS. Rolling back the firmware resolves the issue
