Beta firmware 360-60 issue not generating power from MPPT solar devices
Work around: install official release
Hi @jaap.wind , would it be ok of one of us logs into the system to see it in more detail?
You’ll then need to enable Settigns → General → Remote Support.
And if there is a possible solution, is it ok to make a change to the system (update to a yet newer version)?
If things go wrong / don’t work, you can always revert back to v3.55 again.
thanks, Matthijs
Hi Matthijs, I enabled remote support, you can play with the versions, a cerbo reboot wont affect power in house
ID is 124481
Hi Jaap, thanks - something seems wrong indeed. I’ve made a note and will be picked up next week.
I had same problem caused by missing grid meter.
Some Here!
No connection with Victron-VM-3P75CT by Modbus TCP /UDP I try something but nothing works…after downgrade to previous version it works immediately.
Hi both - yes that’s the issue. Will be fixed after easter and meanwhile downgrading is the best solution.
Hi!
this was caused by a bug related to connection to the VM-3P75CT meter.
Fixed per v3.60~65 available per just now.
Great Matthijs, all devices up and running on V3.60~66
