V3.60~49 - DC system is no longer displayed
I have just updated from V3.60~39 to 3.60~49 and since then the display of the DC system (SmartShunt) has disappeared.
However, the Detain information is still there.
If I activate the entry “Show DC loads” in the SystemSetup,
the consumption of the DC system is displayed, but I do not want a “Calculated estimate of DC consumption”, but the measured results of the SmartShunt.
If your SmartShunt is set as a DC Energy Meter and the type set as DC System then when you activate “Has DC System” in the setup menu, the DC box should display the SmartShunt, not the calculation. Mine does. The way to test it is enable “Has DC System”, tjen on the overview page click on the DC Loafs box, if it is the Calc nothing happens, if it is the SmartShunt it will go the the device page.
Thank you, for you quick response.
In this case, the description would be incorrect.
What is still called “Has DC system” in GUI-V1 is called “Show DC loads” in V2. This setting is described as “Calculated estimate of DC consumption”.
However, if I understand you correctly, these are not calculated values, but measured values if a smart shunt is installed.
Yes, the SmartShunt over rides the calc when set up as I described.
