I hope this is a bug?
On the brief page in v3.60~39 there is much less information about the battery than before. Above all, the SoC is now very small. But there is a lot of unused space.
Would be nice to have a view like this for my ESS-System.
There is something in the changelog about mods to the brief page view with updates coming. I think it also said that there are new settings.
https://community.victronenergy.com/t/venus-os-v3-60-39-available-for-public-testing/13471/89
I agree, the new default looks strange without any data in center. I think it should always present key data from first selected (Battery by default).
I only have one (battery), so I have removed all on settings and got old behavior back.
Okay, thank you very much. I didnât think to deselect the battery at level 1, because I already have a battery. Now I have the old design back.
By the way.
Do you or someone else know what the function for the entry âremainingâ should be?
At my system there has never been a value for that
Same problem here on LFP with REC ABMS - I think it depends if your BMS provides this data.
The center digits have been discussed many times before, iirc it was on a todo list for the design.
The moment you had a second âringâ on the brief page, such as a tank, then the center information disappeared.
There is a longstanding topic in beta open for this as well.
Is that Issue solved now in v39?
V3.60~20 canât uncheck ess - system feed in limiting
I have installed the 3.60 v39. It seems that the issue is solved. I could change the switch feed in limiter
Hi all, nothing being shown in the center, when having only one circular guage, is indeed a regression/bug.
Weâll look into that - thanks
Nice solution for this at v3.60~46.
And the (for me) useless text âremainingâ in the center gauge disappeared, too. Thanks
For me the Battery-Voltage could be removable at the center gauge, too. In my opinion this is not an information for lay people in case of an ESS. For lay people only W ist neccessary to see whatâs going on at the ESS.
