Raspberry Pi 4 Venus OS v3.60~20 OLD GUI no longer works, blank screen. On 7" screen as well as remote console.
Are you using gui mods?
I would roll back while it is resolved, all part of the beta experience. ![]()
After an upgrade Raspberry Pi 4 Venus OS v3.60~20 OLD GUI no longer works, blank screen. Same for attached 7" touchscreen as well as remote console. Any solution?
P.S. I am aware that NEW GUI isn’t supported for Raspberry Pi 4 attached displays. Just trying to get an OLD GUI running.
Thanks in advance!
No sir, never used mods
Same Problem her. Update to v3.60~21 and the problem is still there.
Are you else using any modifications or drivers like dbus-serialbattery or dbus-mqtt-battery?
In the meanwhile you can use GUIv2 to start the backup firmware. Just change the URL from v1 to v2.
Update to v3.60 ~25 and the problem is still there.
White screen on the local raspberry display and on the v1 gui version on the web.
The log file in /data/log/gui/
@4000000067ab583c1446ecf4 *** Starting gui ***
@4000000067ab583c187066ac using non virtual framebuffer fb0
@4000000067ab583c208445ac "using /etc/venus for runtime features"
@4000000067ab583c2091e5f4 "running on raspberrypi4"
@4000000067ab583c247361fc Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
@4000000067ab583c2ad8be0c Creating settings
@4000000067ab583c2d65f0cc [VeQItemExportedDbusServices] Registered service "debug.victronenergy.gui"
@4000000067ab583c38716104 language is "de"
@4000000067ab583c39c6bbbc accessLevelChanged: 2
@4000000067ab583c39c6d32c setAccessLevel: 2
@4000000067ab583c3b54fcdc LocalThemeDaemonClient: Looking for assets in "/opt/victronenergy/themes/ccgx"
@4000000067ab583c3b59a05c Screen: 800x480 203x122mm 100.099x99.9344dpi
@4000000067ab583d01695dc4 TimeZone::valueChanged: "Europe/Berlin"
@4000000067ab583d016db70c ScreenSaver::dbusDisplayOffTimeChanged: 1800
@4000000067ab583d016f939c ScreenSaver::enable
@4000000067ab583d016f9f54 ScreenSaver::screenOn
@4000000067ab583d27e9a4cc file:///opt/victronenergy/gui/qml/main.qml:12:15: Type PageMain unavailable
@4000000067ab583d27e9c024 initialPage: PageMain {}
@4000000067ab583d27e9cbdc ^
@4000000067ab583d27efa00c file:///opt/victronenergy/gui/qml/PageMain.qml:64:3: Type PageBattery unavailable
@4000000067ab583d27efb394 PageBattery {}
@4000000067ab583d27efbf4c ^
@4000000067ab583d27f7be2c file:///opt/victronenergy/gui/qml/PageBattery.qml:1:1: module "QtQuick" version 1.1 is not installed
@4000000067ab583d27f7d59c import QtQuick 1.1
@4000000067ab583d27f7dd6c ^
@4000000067ab583d27f8c3e4 loading QML files failed
@4000000067ab602d14eccdcc ScreenSaver::timer
@4000000067ab602d14ece154 ScreenSaver::screenOff
I had exactly the same problem and fixed it with upgrading dbus-serialbattery
from v1.5.20241215 to v1.6.20250131
“1) latest release “v1.6.20250131” (mr-manuel’s repo, stable, most up to date)”
-Andreas
perfect. all works fine now
