Just upgraded from v3.33 to v3.54, generally pretty happy.
On the brief page, Quattro input power levels are displayed on the LH side, and these show as solar and generator – which is currently turned off since I’m plugged into shoreline, and I’d like to see the power drawn from this not the (off) generator.
Since the Quattro will only ever draw power from one of the AC sources, surely the power displayed should be generator (if this is running – AC 1) or shoreline (if this is connected – AC 2)? The symbol should then change to show which one is active.
When I open the side panel, it correctly shows shore power – and not generator power, I assume this will change if the generator is running?
