Hey Matthijs,
Tank sensor resolution increase is great, but the current value is still only one decimal place. I’m also not sure if it’s happening on this version but when using the touch interface on ~7 I was unable to name a tank sensor. You tap in the name field under “Device” and it doesn’t give you any ability to change the name.
