Unable to delete old temperature sensors
Great info and lateral thinking, thanks for writing it up.
Would you be willing to go a step further and take some screenshots or even a screen recording of that process?
I think that might be the final solution for people such as yourself where the “official working solution” has this gap for some people.
Presumably those now stuck with the phantom sensors tried deleting them from the device list before the feature was added that removed them from the dashboard at the same time, so are now between the worlds.
@christiangurk Maybe it’s easier to create a virtual tempsensor with the VRM id?
I am wiling to try that but I don’t know how to find the VRM id of my ghost temperature sensor.
The temp sensor is not in the device list. Do you know how to find the VRM id of a ghost temperature sensor?
Mine was shown in the “Advanced” Page
when opening the “widgets” popup
Maybe yours are shown here also?
I had that idea too, but I don’t know, how to create sensors with a specific VRM-id… I know there are python-functions you can call (I looked them up in the dbus-mqtt-devices source code). For me it worked good, because my ghost IDs were close to the beginning, IF you have e.g. a ghost-ID of 2048, then my solution wouldn’t be practical.. In theory it should be possible witch command line commands in the console also… But You have to perform several steps to really create and “activate” a new sensor so for me it was the easiest to use dbus-mqtt-devices. Maybe we can ask freaknt to implement a feature to specify a VRM-id upon creation of a device in his code, so it would be much easier to use for high VRM-IDs…
@christiangurk @guystewart
Yes I found the ID = 71 in the widget section. Thanks.
I will try to make a virtual temp sensor in node red and try to assign VRM id 71 to it…
I found this setting in the CerboGX to change the VRM ID’s:
Changes requires a reboot of the CerboGX so now rebooting…..
After reboot I have a virtual temperature sensor with VRM id 71
and a “real“ ghost sensor with VRM ID 71
and this is shown in the VRM
fingers cross and let’s delete the virtual temperature sensor with id 71 from the device list……
BINGO!!
Finally after two years the ghost sensor is gone!!!
Hi Guy,
sorry that I didn’t took screenshots during my actions. But I wasn’t sure if it’s working at all :thinking:
And also, I suppose, the process might be different with different sensor types and/or versions of dbus-mqtt-devices. So I think, people with this ghost devices already played around with dbus-mqtt-devices or node red and will find it’s way to try to remove their ghost sensors itself. As an addition to the above, I used MQTT-Explorer to send the mentioned messages. But I assume, everyone using dbus-mqtt-devices and venus will use MQTT-Explorer to check their setups anyhow.
So if there are more people having problems to get rid of their ghost devices, I’ll try to help here and we’ll see, if a “tutorial” will be necessary.
Do we know if this was implemented?
I have this data being sent for a virtual temp device:
{ “/Temperature”: null, “/Status”: 1 }
Yet VRM still shows the last temp sent (15 minutes ago)
I guess the challenge is how is a stale (old value) handled vs how is a null value displayed on the Dashboard?
On the advanced page, the chart correctly shows no data for the current time stamp… it seems there is still a small UI bug on the VRM dashboard ?
