UI v2 - inverter
I’ve had a look around the forum and I cannot find anywhere to suggest improvements to the UI.
I think v2 of the UI is much improved. I’ve been using GUIMods successfully.
The main reason is the number of clicks/presses to alter the state of my inverter.
Several other screens offer a multiple option rather than clicking several times.
Here’s my suggestion of simplifying - and vertical on the route where you click top left.
Down from 4 clicks to 2.
Upper left corner opens a menu where you can control your inverter.
Hi… that’s what I meant by “and vertical on the route where you click top left.”
It’s 4 clicks from that route and 4 clicks if you press the Inverter.
I think it should be 2 clicks.
1 - either the top left or Inverter
2 - click on the [On] or [Charging Only] or [Inverter Only] or [Off]
The thing I like about Gui Mods is you press 1 of the 4 options and you don’t need to confirm.
It’s not needed imho.
Thanks
The response to that are the inadvertent system shut downs that occur from accidentally catching the wrong setting, and multiple requests from people for a confirmation step.
No pleasing everyone I guess.
I’m in the “I know what buttons I’m pressing so why do I need 4” camp…
My digits get tired :face_with_peeking_eye::wink:
I’ve ended up setting up NodeRed. Then on my Android phone I’ve installed HTTP shortcut.
It’s great.
