Two different MPPT on same load disconnect smart BMS CL 12-100
Hello everyone, new here
I am installing off grid system on my Smiley Transit old-timer 1994 petrol. Started few years ago with some Chinese set 100Wp and PWM and lead acid car battery, “good” for some light and phone charger,…..
Updating now. I left the fixated 100Wp panel on the roof, added a 260Wp panel I possessed already, no more space on top.
My question is: can I control both different MPPT chargers by same BMS load disconnect?
Or do I need complete other setup?
Total view attached,
TIA
Connecting the two non-inverting remote on/off cables in parallel to the Allowed-To-Charge output works fine.
If i remember correctly the Smart BMS outputs 12V as long as the chargers are allowed to charge and pulls the output to ground otherwise (or vice versa). But the core of it is, you can connect many remote on/offs in parallel since the signal is nothing fancy
