Trying to understand why my solar PV batteries have failed so soon?
This is the maximum recommended charging current in relation to the capacity. This has nothing to do with efficiency.
The term efficiency of a battery describes how much of the charging current it can get back out.
No, it makes it 10 times faster. Again: efficiency has nothing to do with it. Your car is not more efficient than others when it can drive faster :slight_smile:
But probably just as important: you should not charge a 48V-100-Ah-lead-battery faster than with 10 to 15A which is around 500 to 600 W. So you can’t use it with a larger PV array.
Danke für den Input, aber das glaube ich nicht. Es gibt zwei englische Begriffe, die häufig verwechselt werden: efficiency und effectiveness. Die gleiche Verwirrung gibt es auch bei den deutschen Entsprechungen “Effizienz” und “Effektivität”. Bei letzterem geht es darum, ein gesetztes Ziel zu erreichen, und wenn das Ziel darin besteht, einen Akku möglichst schnell zu laden, dann ist ein hoher Ladestrom effektiver als ein kleinerer, aber er ist nicht effizienter.
I love Germans. We Americans can get a little loose with our words. You Germans don’t. You say what you intend more often than we do.
We Germans constantly scour the entire internet looking for the mistakes of others so that we can correct them as quickly as possible :slight_smile:
What would we do without you?
This is no joke. Look up the Japanese word “mokusatsu”. This word is what determined the fate of Nagasaki and Hiroshima in WWII and may have been interpreted incorrectly.
There is no word for the Holocaust in the German language. And yet it is as German as anything can be.
I’m a physicist and my knowledge of lead-acid batteries is limited to what you learn from working with the batteries in your own car, camper van, and houseboat. What exactly would you like to know?
I’m 70 years old now and retired. During my studies, I focused on low-temperature physics (superconductivity, etc.). Back then, almost all the jobs for physicists were in the nuclear industry and the chip industry, and I didn’t want either of those. So, after completing my physics degree, I also studied architecture and then worked at the university for a while. I earned my living with software development, and later I also trained building energy consultants.
I have Asperger’s and am therefore practically addicted to knowledge; I’m interested in almost everything, and I want to know everything and understand how everything is connected. If it had been offered at a university in my region, I would have also studied cultural anthropology, and perhaps philosophy and politics as well.
But my knowledge isn’t just theoretical; it’s primarily shaped by my experiences. I lived on a sailboat in Sicily for many years, later on a houseboat on the canals of France, and then traveled throughout Europe in a motorhome. I installed the energy systems myself in all the boats and motorhomes, and in doing so, I acquired considerable knowledge about photovoltaics and batteries.
And before you ask: I still don’t know what I’ll do when I grow up :slight_smile:
Ditto, I also suffer from Asperger’s and have been addicted to electronics from the age of dot, kicked off back in the early sixties by the Ladybird ‘Magnets, bulbs and batteries’ series of books. I’ve spent most of my working life self employed, designing and building control equipment for automating piling rigs on building sites, which had to be battery powered and extremely resilient, but I’ve never had to deal with the practicalities of battery management until I installed the solar PV system and suffered the problems I’ve described above. My ‘smart’ home is full of home built sensors and controllers all powered by the solar PV system. It’s not often I’ve come across anyone with a similar background, so always interesting to hear other peoples stories :slight_smile:
PaulM
It’s nice to meet someone who is cut from the same cloth as me. Interestingly, I don’t “suffer” from having Asperger’s; in fact, I’m quite happy with it. It’s more everyone else who suffers because of it.
We simply have to accept who we are, and even if everyone else thinks we’re aliens, we can still lead a happy and fulfilling life.
Please do not spread fake information. There is no LFP lithium battery that can last less than 1000 cycles, and that’s down to 80% of original capacity. No matter how bad you manage them, the built-in BMS will keep the cells under specs. Even the worst LFP batteries will easily give over 1000 cycles, unless the BMS gets damaged due to system misconfiguration.
This is rather broad and misleading.
Commercial batteries will typically state in their specs as part of warranties etc and it will vary, some are far above 6000 cycles.
No LiFe battery will only get 10 cycles, you are conflating different chemistries which will be confusing.
Building DIY batteries is also not for everyone. If you don’t know what you’re doing you can have real problems, as we see from the many issues that get logged here. It is a project not suited to everyone, that the internet has managed to convince people is incredibly easy.
Yes, exactly right, ‘suffer’ was the wrong word to use. After 70 years you become used to dealing with the ‘non-aliens’ who don’t have the same advantages as us :slight_smile:
PaulM
Yes, it’s incredibly easy, much easier than, for example, assembling an IKEA shelf yourself. I did it myself. And yes: as with most other DIY projects, you need to know what you’re doing, and above all, you need to be aware of the dangers.
That would be amazing, 10x the life I’ve had with the AGMs would be 35 years, by which time I’ll be 105, hopefully sat in my rocking chair on the patio watching the world go by and not worrying about solar PV or batteries :slight_smile:
Thanks, I’ve added the data sheets to all the other info. I’ve accumulated, this whole thread has been very educational. I shall spend some time now looking at everything that has been suggested so hopefully in four years time, when the batteries need replacing again, I’ll be in a much better position to upgrade to something more permanent.
Any experience with the Victron Battery Balancer, Battery Balancer | Victron Energy ?
PaulM
My gut feel also is it’s a bit pricey for what appears to do, but there again so is the rest of the Victron kit, you pay for their research and expertise as well as the cost of building the kit, not to mention the convenience of buying something off the shelf that you know will work reliably.
The operation appears quite simple so along with investigating the diyBMS etc. I may have a play with a diy version once I have new batteries installed in the PV system. Theoretically it shouldn’t even need any ‘intelligence’, but what equipment these days doesn’t have a couple of microprocessors built in for driving a few LEDs ? There again, if the diyBMS/Lithium batteries comes to fruition I won’t need it !!!
PaulM
It’s important to understand that LFP cells don’t age as much over time, but rather due to temperature stress. This stress can be managed, for example, through battery design with good temperature management, or by the user themselves by avoiding high charging and discharging currents.
For my EVE 280K cells, the manufacturer specifies a cycle life of 8,000, but at a maximum charge or discharge current of 0.5C. Manufacturers of batteries using the exact same cells often specify a cycle life of only 4,000, but at a maximum charge and discharge current of 1C. This clearly illustrates the impact of high currents on heat generation.
Because a smaller battery wouldn’t have been cheaper, I opted for a larger battery than necessary, namely 15 kWh instead of just 8 to 10 kWh. This will hopefully lead to an even higher number of charge cycles, as my charging and discharging currents are now only a maximum of 0.3C, and my battery will still be perfectly usable for many years even after its “official” end of life when its capacity drops to 80%. It will only become critical for me when my battery’s remaining capacity drops to 50%. Even if the larger battery is more expensive, the extra cost is offset by the significantly higher number of charge cycles and longer lifespan.
And another advantage of a battery that’s actually too large: You can then use a smaller inverter than the installed PV capacity and still feed all surplus power into the grid. I only have an MP2-3000, which delivers a maximum output of 2.4 kW, but I have 5.4 kWp of solar power. The surplus power is stored in the large battery and fed into the grid at a constant rate, for example, overnight. This significantly reduces my costs.
