Transistor GX IO Extender
Hello everyone,
I would like to use the digital outputs of the GX IO-Extender to activate 12VDC relays. Can someone help me with the choice of transistors that can be used ?
Thanks !
If more than one output need to be used, then a compact and cheap choice could be ULN2003 or ULN2803.
Or use cheap modules like these: Amazon.co.uk : 8 Channel DC 12V Relay Module
thank you very much, I will try this!
Can you tell me what you used and if it works like intended?
Strugling because Victron states only 4mA max output on digital output.
Kr Stefan
I haven’t done my tests yet but I ordered Mosfet IRLZ44N which normally consume less than 4mA.
Best regards
Frédéric GRONDIN
for the PWM i use: 20 Pcs DC 5V-36V 400W FET Trigger Switch Drive Module Board Dual Mosfet Driver Module Dual High Performance Switching Driver Module PWM Controller Switch Panel Driver Module for Ar-duino : Amazon.de: Business, Industry & Science
For the outputs I use: PENGLIN 1 x 4 Channel 5 V Relay Module with Optocoupler High or Low Level Trigger Extension Board for Raspberry Pi Arduino : Amazon.de: Computer & Accessories
Additional needed for the relais: Bauer Electronics DC-DC 8V-32V to 5V Voltage Converter 3A 15W 12-V 5-V Buck Converter Power Supply 24V Voltage Regulator Voltage Stabiliser Voltage Limiter Step-Down Volt : Amazon.de: Business, Industry & Science
Best regards Andre
Hi Andre,
Thank you very much!
KR Stefan
IRLZ44N work - but remember they are low side so are not suitable where common grounds exist. We experimented with these when the Extender 150 was release but eventually went with the BTS7000 series of smart high side power switch - this allows us to monitor current draw and provide smart fusing etc… But if you’re set on the IRLZ44N’s then they are a good Mosfet for the job and will handle PWM nicely too .. here is a pic of our 8 ch prototype ..
HI Andre,
I have ordered the Amazon.de but I have some issues.
I have 2 GX 150 I/O modules and they have the same issue. Tried them also on 2 different Penglin boards.
The firmware I use is 3.71 and if I togle just 1 relay, all my relays go kinda on. If I togle more on, the red lights on the relay board will shine more.
Is it for you still working and on what FW?
KR Stefan
@StefanVerbiest
I’m looking to run relays from the i/o as well , I plan on using the boars below . my tests show 1-2ma per channel . board takes 12v for fet side .
