Hi. I have a Cerbo GX and want to use the relays to operate wet bay heaters in my RV. I already have temp sensors in both wet bays. I want to use 12V, 100 Watt, 8.33 Amp heaters. Can I wire them directly into the relays so I can program the Cerbo to turn them on and off using the temp sensors? Or do I need another relay between the heater and the Cerbo relay because of the amperage? Any help would be greatly appreciated.
Go to the Cerbo GX product page, scroll down to downloads and download the datasheet, it gives the relay specs.
https://www.victronenergy.com/communication-centres/cerbo-gx
You will need to drive another relay. Beware, many people have burnt out Cerbo relays, but a relay with a flyback diode or add one yourself.
See the FAQ
thx
