The “Total Consumption” energy value in the upper right corner in VRM shows the same value as further down in the history section (OK).
The “Total Solar” energy value below that however shows a value that does not seem to make any sense. The power value is accurate. How is the energy value calculated?
Do you have the time/date filter set to last 24 hours? I believe the top graphs are always -24 hours, and the bottom numbers adjust depending on what the filter is set to.
I’m wondering if that figure is coming from your solar charge controller? I have an AC-coupled inverter and that figure doesn’t appear on my system. Have you checked that?
Be sure you aren’t ending up with double accounting on virtual meters.
There are also some known issues with the node that can record incorrect spikes - requiring a setting change on the node.
