Temperature sensors build in multiplus available in Nodered
Hello everyone,
I have had a Victron system for a number of months now, consisting of 3 x multiplus, Cerbo, Shunt and a 32 kWh battery.
This entire system is built into a large control cabinet.
I am now working on installing a fan to cool when the Multipluses have to supply a lot of energy.
For example, it would be useful if the inverter temperature were available in Node Red. Then I can create a flow to switch on the cabinet cooling via a relay. So far I haven’t found this in Node Red.
Flow like if Multiplus 1 or 2 or 3 temp > 30 then start Fan.
You can use a programmable relay on the inverter (ve config) to create a signal for when the internal fans run, then use that to trigger other fans.
