Temperature reader on GX touch 50
Why doesn’t the temperature reading appear on the main screen next to the energy values? You have to go to the menu to take the reading.
What temperature sensor are you using?
Usually temperature is environment information (which is where it is in the new gui), unless it is connected to the battery terminal and them more ideally to the inverter. Then it will appear in the batery information.
RuuviTagPro 3en1 The temperatures are only on the level screen. I would like it to be on the main or native screen
