Cerbo GX m2
Hello
I have a Cerbo GX m2 with the latest software.
My problem is that I have not been able to get the temperature on the display GX Touch 50
In the center I have battery information
I would also like to get the temperature on the display
Anyone know how to do it?
The temperature from what device what is it the temperature of? how it it connected?
Are you wanting it on the gui front page?
Do you know there is a dedicated environment page for display of environmental temperatures?
Hi
The temp sensor is connected correctly, I can see the temperature, but I can’t get it to show up on the home page, that’s the problem I’m having.
Environmental sensor appear under levels and environment.
Not difficult to get to.
They aren’t designed to be on the front page as far as i know unless they are related to the installation like the battery temperature is.
Okay I thought you could get it on the home screen
But then I know
Thanks
What are you measuring with the temp sensor?
To keep track of the
Fridge
Ok. So it is an environmental one definitely.
The fridge filled with cold beer needs permanetn survilliacne and alerting, is a critical load, hopefully conneced to AC_out1 or directyl to DC.
Just kidding :wink:
BTW I have all my fridges, freezer and network on AC_out1.
@Per1
Venus OS (Cergbo GX) is not a configurable home automation system.
If you have advanced requirements, have a look into free Home Assistant (HA), which can be integrated with Venus OS. There you can build any dashbaord with any sensor and even on maps of your building/van/boad. HA integrates nearly everything from IoT devices (ESP32,Tasmota), ModBus, MQTT, properiatary APIs up to cloud services.
