I was running classic Touch 70 UI and the three tank level displays began reading erratically over time. They then all failed to display at all. In Setup I could not see them as devices. Upgraded to the new UI and same problem. In fact the Setup menu item for the sensors does not even appear. Only thing I can find online similar is a faulty Cerbo. Checked connections and all OK. Any advice appreciated. Cerbo is about 2.5 years old.
Related topics
| Topic | Replies | Views | Activity | |
| Analog Tank Sensors Don't appear in Device list | 5 | 228 | February 25, 2025 | |
| Custom tank levels | 0 | 88 | December 9, 2024 | |
| Custom names for tank level sensors Cerbo GX not showing on Touch 50 | 5 | 193 | August 7, 2025 | |
| Tank sensor showing Error status when 0% | 1 | 60 | January 29, 2026 | |
| NMEA 2000 Tank Adaptor (YDTA-04) and Cerbo with OS 3.60 | 5 | 227 | June 29, 2025 |
