Switching from lead to Lifepo4 (easysolar and bluesolar)
Hi there, after six years I am planning to switch from lead agm batteries to lifepo4 batteries. My current system looks like the attached drawing. Is there anything I should keep in mind while doing the switch (except for changing easysolar and bluesolar charging profiles to lifepo)?
My bluesolar is not connected to easysolar at all, instead it acts independently and feeds power directly to shunt. Is that a problem? My thinking is that the BMS sitting on top of the lifepo’s will keep everything in check.
