I found a few topic to similar themes, but no one fits to my setup..
My RV is using a 24 Volt battery system, powered by a 24V alternator, in the living space i use a 12V system
The connection between the 2 systems is a Orion-Tr Smart 24/12-20A DCDC Charger.
Additionally i use a SmartSolar MPPT 100/20 (connected to 2+15W 18V Panels (serial connected → 36V)
Backup is a Blue Smart IP65 Charger 12/15, but all this is only capable of loading the 12V System.
My question is now what happens if it is necessary to charge my 24 V System?
My idea is to add a switch (Zero position) into the Solar Charger battery line.
So it would be possible (in case of I need it needed) to switch of the 12V battery from the unit and switch on the 24V battery.
I know it is manual and it only allow to load either/or but for the worst case it should work.
At the campsite I normally have 230V, so there is no actual need for the Solar array…
My question is only the configuration… there is no “auto setting for battery voltage” in the app.
is it really necessary to switch the voltage also manually or the MPPT will change correctly because of the connected battery voltage.
