Hi - I am using a Smartsolar MPPT 100/30 to charge my 24v boat batteries (fed by 2 x 130W panels, soon to be doubled to 4 panels) and was advised by community members to use an Orion 24/12 30 dc-dc charger to charge the boat’s 12v batteries from tge MPPT unit output.
The dc-dc charger puts such a load on the MPPT controller when it switches on (bulk charging) that the input voltage drops significantly resulting in the dc-dc unit shutting down - voltage then recovers and the dc-dc charger cycles on and off ever few seconds, which I assume isn’t ideal for charging.
I have fitted isolator switches between both units and their respective batteries.
All batteries are bog standard lead acid; 3 x 110Ah in oaralkel for the 12V system and 4 x 110Ah in series-parallel for the 24V
Any advice on unit settings or physical configuration would be welcome!
