Switches - Relay display in new UI
Hi all,
First post here!
I have a Cerbo-GX and attached display. Firmware is v3.51. I installed the new UI.
I have relay 1 configured for temperature control for my Lifepo4 battery, and relay 2 is not configured yet.
In the Brief view of the display, I can press the switch icon on the left upper side and display the switches. But I only see Relay 2 with a manual control.
I don’t see the status of relay 1.
Is it possible to display the status of relay 1, without going through the 5 levels deep to see if the condition 1 is active or not?
Thanks!
Simon in my Promaster at -20°C ! :wink:
I saw this post : Bringing relays on startpage - #2 by MitchMe
But the one relay configured for temperature control is not showing there.
Also, updated to version 3.52
The available relays are visible when set to manual operation, allowing you to control it. Otherwise they are configured and managed under the relay section.
Thanks for taking the time. I assumed as much.
Maybe I was not clear enough.
I’m looking for a way to display the relays on the brief or other pages.
Is there a way to customize those?
Unfortunately not. You can post a feature request in the modifications space for consideration.
Hey, this is coming; and now available for beta testing and feedback.
Details here: V3.70 betas: internal relays moved to the Switch pane
@mpvader Thank. Configured it on my testbench yesterday and very handy.
