In the VRM portal, the data for “Battery to Consumers (kWh)” shows sudden spikes, where the spiked values are clearly incorrect. The normal (non-spiked) values are accurate.
Why do these spikes occur? What algorithm does Victron use to calculate “Battery to Consumers (kWh)”? What parameters are involved in the calculation?
As shown in the attached screenshot, the actual load power is 1kW. Over a 15-minute interval, the energy consumed from the battery should be around 0.2kWh. However, the spike in the chart is much higher and clearly incorrect. Why does this happen?
