Hi all,
I am experiencing an issue with my Orion XS 12/12-50A that continues charging even when the engine is OFF. I would appreciate technical insight.
System configuration
Vehicle: Camper with smart alternator
Installed Victron equipment:
2x Victron LiFePO4 200Ah NG batteries (12.8V)
Lynx Smart BMS (NG system)
MultiPlus-II 12/3000/120-32
Orion XS 12/12-50A
SmartSolar MPPT 100/30
Cerbo GX
The system is normally fully integrated via Cerbo GX.
Orion XS configuration
Function: Charger
Charger enabled
Input current limit: 50A
Output current limit: 50A
Engine shutdown detection: Enabled
Alternator type: Smart alternator (12V)
Settings:
Start voltage: 14.0V
Delayed start voltage: 13.3V (120s delay)
Shutdown voltage: 13.1V
D+ / Remote testing
Real D+ signal measured:
Engine OFF → 0.0V
Engine ON → ~14V
Tests performed:
D+ connected to Remote H, Remote L to ground
Remote connector completely removed
Orion disconnected from Cerbo GX (VE.Direct removed)
Engine shutdown detection enabled
Observed behavior
With:
Engine OFF
Shore power active (starter battery around 13.0–13.2V)
The Orion XS enters Bulk charging, typically:
Input: ~13.0–13.1V
Output: ~13.3V
12–15A charge current
Even when:
D+ = 0V
Remote terminals removed
Cerbo GX disconnected
The Orion still responds to input voltage and starts charging.
Questions
Is voltage-based engine detection always active when enabled, even if D+ is present?
Can the Orion XS be forced to operate ONLY based on D+?
Does the NG BMS or system integration influence this behavior even when VE.Direct is removed?
What is the recommended configuration when shore power raises the starter battery voltage above 13V?
Goal:
I want the Orion XS to charge ONLY when the engine is running, while keeping full Cerbo GX integration.
Thanks in advance.
Kind regards,
Harry Smulders
