SSH Login fails
Maybe I‘m too stupid…. I am presently trying to get access to the file system of my MP2 5000 GX, because I need to install the serial battery driver by Louis van der Waal on Github. I have configured and enabled the SSH access in the system settings. I have defined a simple password and even started a reset afterwards.
But then … neither Putty nor a BASH terminal works. Perhaps I‘m using the wrong user?
I have tried „ssh Superuser@10.0.1.84“, „ssh superuser….“, „ssh root…“, „ssh venusos….“, „ssh Victron….“, but nothing works. The IP is fine - the device actually reacts and prompts me for the password. But then - just „access denied“.
What am I doing wrong?
Use root along with your setup password.
How exactly? I tried ’ssh 10.0.1.84‘ - the response is ’root@10.0.1.84:password‘ - I entered ’root+password’ but didn‘t work again.
Is the gx on super user with a password set?
Yes, indeed. Otherwise a ssh password cannot be set!
what do you mean by this?
I tried to follow this hint: [quote=“dognose, post:2, topic:11063”]
[/quote]
but actually I have no clou what this means.
This means that you should use root as the user and once it shows the password prompt to just type the password you have set, nothing else.
so:
ssh root@ip-address
password: <type your password here>
It finally worked: the reason was as simple as can be: Password must be at least 6 char. I used only four. Only when I changed it about the fifth time, I got a readable feedback about that issue! I am sure this is somewhere in the docs, but the hint should be there where you enter it. At least more clearly. I will mark this as solved.
