[Solved] Multiplus stops as soon as Cerbo GX is connected
@M_Lange
  1. My 12 yr old MP cannot be updated anymore because of old processor.
  2. I did not switch off the MP from GX device (I have seen those problems in other threads)
@Fideri
  1. That was one of the things still on my list to try, but I had no confedence that this would help, but in the end it is “a possibility to try”.
  2. I didn’t used the softswitch.
Thanks both for your suggestions.
This morning I thought, probably I have set the Cerbo to automatically update the firmware. And yes, that was the case. And because the firmware was at v3.60 (and there were several problems with it), I have 1. disables automatic updating the firmware, 2. manually updated the firmware to V3.63
And guess what?
It works flawlessly, just as before!
So the solution for this problem was updating the Cerbo firmware from 3.60 to 3.63.
