I’m currently running VenusOS v3.60~72 with 3 MP2/5000 + Solaredge Se10k-RWS
Having a look at the PV yield e.g. shows power to be between 9.9 and 10kW
which should give a total energy of approx 10kWh.
Having a look at the inverter stats (Solaredge) it also give me approx 10kW.
However, dashboard system overview is shown with only 7kWh production for the same hour and in totals it’s also reporting 3kW less.
This seems to be a sporadic issue … most times values match all the day, some other days only one hour does not match, but a few days see this lasting for 3-4 hours.
Any idea what might be wrong and how to fix this?
Planned to switch to CerboGX-mk2 … hope it’s gone then …
although I expected this is not a issue of VenusOS but a VRM issue?
