Have a boat that spends a lot of time pierside in a marina on shorepower. One of my holy grails has been to use solar to keep the batteries charged (even if battery level goes down at night) and only use shore power as necessary since it is expensive and solar is free. When at sea or at anchor, we have gone weeks without having to run the engines to recharge the batteries, so was thrilled to discover that solar-wind priority is a feature now available for my Quattro inverter. Have enabled it per the (simple) manual associated with that feature, but it is simply not working correctly. The quattro goes through bulk and absorption modes before entering and staying in āfloatā mode, but it keeps providing power to the batteries/DC system whether solar is available or not and (at night, when solar goes to nothing) maintains the batteries at 100%.
System details:
- 1800 Ah of 12V lithium batteries (bank is 18 100Ah Dragonfly (Battleborn) Lithium batteries. They do not have a comms connection and do not talk to the system.
- BMV-712 Battery Monitor with a Shunt on the house battery bank
- Quattro 12/5000 Inverter charger
- 3 Solar smart MPPT controllers controlling three different parts of the solar array
- Shore power at AC1 in to the. Quattro at 120V/60Hz.
My specific settings for the Quattro are as follows:
DVCC is turned on with Shared Current Sense and Shared Voltage Sense switches on. The three Solar MPPTs are connected to a smartbus with the BMV, and obviously the Quattro is talking to the BMV and Color GX device via the VEBus.
The solar controllers have a Battery Absorption and Float settings .1V higher than the Quattro (this is a previous setting from before the solar priority feature was added to the Quattro in an attempt to try and have the battery pull more from solar than shore power when solar was available).
The BMV has the following settings:
The Color GX appears to show that Solar Priority has been enabled. Overview page shows the solar and wind logo over the battery with an orange stripe at left and two up arrows, and the Quattro page now shows the "Charging the Battery to 100%) optionā¦but status appears to be stuck at āin progressā.
My problem is that the BMV (and the Quattro) both show the battery at 100%, but the ācharging battery to 100%ā appears to be permanently stuck as āin progressāā¦even after a 6 hour absorption charge where it then reverts to āfloatā. During daylight hours, the battery is charged by both solar and shore power with solar covering a big percentage. At night solar goes to zero and shore power load goes upā¦and the battery stays at 100% and never goes down.
My expected behavior is that shore power will only feed the AC loads (AC1 Out) and solar covers the Battery charge and DC loads. At night the battery keeps feeding DC loads and the battery charge level drops. After 7 days, if the battery didnāt make it back to 100%, the Quattro would use shore power to fully charge the battery to 100% and then things would start over again.
My belief is that for some reason the Quattro logics do not believe the battery is at 100% and thus it doesnāt go into sustain mode and keeps using shore power to charge the battery. This also keeps the "charge battery to 100% switch) for the Quattro in the Color GX to permanently say āin progressā and never get to the expected position where I could initiate an override charge to 100% if I wanted to (and as the manual and video describe).
My assumption is that there is a disconnect between the BMV and the Quattro over the state of the battery, leaving them to believe the battery is not at 100%. I am 99% certain that I have a voltage setting wrong somewhere (either charged voltage, float or absorption) somewhere in one of the devices. I am hoping for guidance on what I am doing wrong.
