Hi is there a Bluetooth monitor that shows each solar panel output separately. I have 8 panels.
only possible solution from victron is using 8 mppts
Yeh that’s all I could work out too. Hard to believe it’s such a big ask
You can try to use 8 micro-inverters and connect them all to Victron AC-out 2 and to the Cerbo GX.
But it’s a tricky question what will be cheaper, 8 Victron MPPT 100/2 or 8 micro-inverters? ![]()
