Gx system on a canal boat, UK
Solar works fine while the shore supply to the inverter is plugged in.
on removal of the shore supply the solar winds down slowly (over a few minutes) to 0.
then does not charge - needs the shore supply to be connected to allow the solar to operate?
GX/MPPT/Multiplus/Orion/Smartshunt/Battery Protect - all work well wen mains supply is on - a
Solar does not charge when shore supply disconnected - the inverter runs correctly but drains battery rather than using solar
any ideas?
