I went away for 6 months and came back to my van, made a firmware update and the solar doesn’t work any longer. It may be the update. There has been another update which I applied recently.
Could there be a setting which was changed in an update?
I have checked all the connections are in. 15.35V comes from the full French sun right now. 13.75V on the battery side. But the battery is not being charged.
I don’t understand what ahs changed, it was fine last year.
Settings can’t just change, with age connections wear or get loose, systems prone to vibration, like vehicles, are more at risk, especially with connections like that which really need to be neatened up. Typically it is something like that. Updates don’t happen accidentally, they must be loaded and settings on chargers are preserved - unlike the vebus inverters.
When using the van power is cut, fridge and lights up, it charged the battery, but not while the fridge, etc are on. In the past the solar could charge the battery even when the van was left in 35 degree heat with the fridge on.
I have measured them at 118.5x54 cm which fits the Renogy 100w flexible panel, and that sounds familiar in my mind, but it has been 8 years since I installed them.
I have cleaned them, and they are still only outputting 29w, midday in South France, on a just about cloudless day, barely noticeable haze.
this leaves the battery discharging in this state.
What should the voltage be at the battery connection? I can see that when I disconnect the solar from the battery that the solar outputs 15ish V. It is sending a little power to the battery, just not much. The power from the solar is making it to the battery positive terminal, but it is very weak.
For the rear panel, I can’t seem to work my multimeter for AMPs, but it’s giving 20V. With me shading it and without. When I remove the front panel from the system, it is sending 30+W to the MPPT.
For the front panel I get no voltage. I guess it’s broken, and again now AMPs.
It’s kind of warm now, 29 degrees, is 32W reasonable for an 8 year old panel that would have been 100W new?
