Solar forecast unavailable in VRM past September 12
in VRM, solar forecast is no longer available past September 12, where it cuts off at lunchtime. Calls to the API yield 0 forecast for any period after that as well.
I have read here in the forum that last year around the same time similar posts appeared that have subsequently been solved by Victron staff. I have also read that resetting the location might help. I have done the latter but had no luck.
Does anyone have an idea what I should try next? I am unaware of troubleshooting guidelines for VRM - if I am amiss there kindly point me in the correct direction.
Same problem here.
I have raised this. Thanks
Same here
This should be resolved in the next couple of hours. Thanks.
As of 9pm September 10 the values are being reported again. Thank you very much for your assistance!
Is there something that I could have / should have done? I am grateful Victron provides basically for free measures to more optimally operate my installation, at the same time if automation depends on it, outages in the service, if undetected, can have very undesirable results. I guess I need to make sure automation checks for implausible values…
