I’m using several SmartShunt 500A units (firmware 4.19, latest VictronConnect). In the technical data is mentioned the battery capacity can be set from 1 to 9999 Ah, but I can only set it up to 999 Ah.
With the last FW you should be able to set it up to 32500Ah.
I just tested it with a new 500A SmartShunt.
Thanks a lot for you help!… our stock is from march 2025. I’ve also from 20.6.205…I’m going to try this one.
