Hi I have an issue with my MPPT 100/20 Smart solar charge controller.
It has a 200W panel connected that arguably only generates 100W. It is connected to a 100Ah Smart lithium liFePo4 battery.
The panel is putting out 20V and the battery is just over 13V. This is demonstrated when I pull the fuse from the PV and measure voltage from The live positive at the fuse to the negative at the controller. If I replace the fuse I measure less than 1V across the PV.
Using my clamp meter I measure 3A passing from the PV to the controller but almost nothing going from the controller to the battery.
I’m really stumped by this and it would be great if somebody could point me in the right direction.
Thanks in advance
Ian
