Smart Shunt Wiring into this battery arrangement
Hi All,
I’m looking help on how I would wire in the Smart Shunt to this battery arrangement. I believe:
  • the negative taped cable is wired to the engine
  • the other negative to a bus bar for mains charger and domestics
I don’t see how I can wire in the Victron smart shunt in to this arrangement?
Thanks All
Mark
Sure can, if you add 1 extra cable, and move the charge/load negative cables to the system side of the shunt.
