For some reason my shunt is syncing to 100% about 5ah too early. It just started after I upgraded to 280ah cells from 100ah cells. I did not reach target voltage. I reduced tail current to 1% amd charge detect time to 5min and still flips to 100% before voltage is even close. Attached it my current setting and current stats
Try reducing your Charge Efficiency Factor.
