I’m doing all that stuff for free… I don’t thing that’s necessary pay just for have a widget card with info on my VRM…![]()
I just added a line for stop the EV Charger when my battery goes down 90%. I don’t know why, but when charging at full solar power (4Kwh) the sistem take some power from my battery. Today when i realized at 18h, the battery was at 81%. and the charger still taking some power from the battery. The option in the charger menu to stop charging when the battery goes under the value you chose, only it’s if you lose the gird, but if not there is no stop for disconect ther charger and recharge the battery to be ready for the nigth. Using Node-Red I added a line for change the mode to Manual and then stop the charger if the SoC goes under 90%. 2 seconds after it returns to Automatic (in this mode the battery must be at 96% to start the charge) Maybe its useful for someone.
Unfortunately, no, because I still don’t use the beta version—only stable versions—so the virtual EV node isn’t available to me yet.
Or do you mean the EVCS node?
Aaaa okok,. I’m talking about the Virtual EV. @nickdb do you know where I can find the expected values for the virtual EV node??
Typically in the node docs in nodered
@grua Do you use a EV Charger from victron, no? Do you now how to change the name of the vehicle in the VRM?? It Allways show Guest EV…
No, I use a go-e charger with evcc and integrated evcc into VRM with a github script
ok!! I will try to find where to change. Thanks!
