I’ll start by saying that I know that it’s not possible to read the SoC directly from the car during AC charging. I solved this using a CAN gateway and sniffing the right messages. So I have the correct and current SoC from the car during charging in node red.
Question:
Would it be possible to display this in a reasonable way directly on the remote console overview? Ideally right in the EVCS rectangle. That would be great
I also thought of creating a car in node red and displaying it via VRM. However, that doesn’t solve my original intention. I have a tablet with a remote console in my living room and generally speaking I like how it works. The solution to completely escape from the beautiful gui-v2 and create my own visualization completely is the way to go. But I don’t want to do it. Anyway, thanks!
(You could also use a virtual Battery for that to get a battery icon, but then you should make sure, that you manually select the actual BMS throughout the system settings)
