I’m trying to set the “Shore current limit” on paralleled MultiPlus II 48/3000s. New UI will only allow to change AC Input 2, which doesn’t exist on the MP-IIs. Switching to the classic UI still allows changing the correct setting. It’s the same issue through the quick side menu and through the device details page.
System: Cerbo GX, Touch 70, 2x MP-II 48/3000 Parallel, LFP Battery w OrionJr2 BMS
