GUI v2 v3.51 - Bug report - Current limit input #
I am currently on V3.51. When connected to shore power on my Multiplus pair, I click on the shore power block of the Ivervirw page so I can adjust the input current limit.
When I do so, the label at the top of the screen is
Shore Current Limit
AC Input 2
It should be AC Input 1 (must be as there is only one AC input on the Multiplus)
Mike
Didn’t see this message before posting the same issue here: Shore current limit input bug in v3.52
Are the systems a parallel set up?
@sy-oxygen
Hit vote at the top since your issue is the same.
Yes, two Multis in parallel
Under system set up, you can set input to to unavailable.
Input 1 has been set to Shore Power.
Input 2 has been set to Unavailable.
I just re-verified this and it would appear that this has been corrected in a firmware update as it now shows AC Input 1 in the Shore Current Limit page.
Closing this as fixed.
